Domain Registration Requests
Thanks for the @ command @Bowend! That helps me to know that you need my help. I was able to get everything I needed to add you to our database via the link you posted so you are all set to deploy the app if you have not already done so. Just make sure you do not miss any steps as you deploy the app as doing that can cause issues later on. If you are still seeing any errors after this post is live, let me know and we can start troubleshooting right away.
@CaseyG just to verify, since i didn’t mean to link our webpage itself, all staff and students use the @bcsdschools.net email domain. Thank you
No worries @Bowend. I double checked and I have the right domain added so you are all set. If you are still seeing any issues please take a screenshot of the error with the developer mode console open so I can take a look at the information in there as it will help me to figure out a solution for you.
I’m struggling to get students to be able to log in to edu.sketchup.com using Google accounts. Our domain is “themeads.org.uk”. They’re getting stuck after going through the login loop with a message that says “Something Went Wrong: SketchUp encountered an issue. Please try again later.”
Hi @MeadsITManager thanks for the post and sorry to hear you are having difficulty with SketchUp for Schools. Can you get me a screenshot of the error message with developer mode enabled and the console tab selected in developer mode? I should be able to get some information from that to find out what the cause of the error is.
The sooner I have that the sooner I can get a possible solution figured out.
Hi @CaseyG, thank you for the prompt reply. I did a lot of troubleshooting yesterday changing and re-adding various settings from your instructions regarding installing the app for the domain, the cookies and pop ups etc. I got it to a point where I did manage to get one child to log in successfully - I’m currently waiting to here from the class teacher to see if this was successful for multiple children. If it isn’t fixed, I will respond with the requested screenshots.
Thank you for your help.
Could you please add our Domain - @chairo.vic.edu.au
Thanks
Mark
(ICT Ops Mgr)
Hi,
I’ve had a time to look further into this, please see the attached image.
This isn’t affecting all children in a class. When 30 children try to login, approximately 50% can, but 50% can’t.
Update: A class tried to log in this morning, and far fewer were able to get in - maybe only 2 or 3 out of 30.
Please add out domains edubs.ch and stud.edubs.ch as we provide service to over 100 schools in one EDU Microsoft tenant.
Thank you
Stefan
Hi everyone, sorry for the delay in my replies, I was out for a while and am still getting caught up. I’ll do my best to address everyone in a single post so just look for your username for the part that matters the most to your situation.
I’ll start off with you @mesmith1070. I checked the database and can confirm that you were added a long time ago and that everything seems to be working on our end. I also booted up our test server to make sure that the app is working this morning and everything seems to be fine on our end. This indicates that something must have changed on your side that is affecting things. Usual culprits are firewall settings or antivirus software. Have you or your district made any changes to that recently?
As for you @MeadsITManager, I can not say I have seen that error readout before. I’ll get it sent over to the develper team and ask them if they have any thoughts on what might be causing it. If students are able to access it at all that tells me a few things though. Specifically, it tells me that the deployment was successful and that they are not getting blocked by our firewall. That is a good thing as it narrows down where I need to look for an answer. It is still early in the morning here as I write this so I will not have a chance to talk to the developers for a while but in the meantime, can you confirm what the specifications of the computers you are using are? Also can you confirm what browser version you are on?
Finally, while I have addressed you in a different thread @stefan.kottke for the sake of completion I’ll say the same thing here. As a starting point, can you confirm what browser you are using and make sure you have enabled cookies and popups for the site? Additionally, if you are willing to share a screenshot of the console tab in developer mode I may be able to get some additional information from that to narrow down potential causes. I have a guess as to the cuase but without more information I can not say for sure. Once I know more I can start troubleshooting with you instead of just guessing.
Hi Casey. Thanks for the follow up. Busy start to the school year and I forgot to update this issue. There were some changes to Defender policy but we have corrected these.
