Disappearing window
Hi, After launching the Sketchup 2020, when I click on any template or recent files in the welcome window, everything disappears. The task bar tells me the software is open but the file window is off the screen somewhere. Same thing happens even if I don’t have separate monitor. I’ve uninstalled and reinstalled the software to no avail. I use PC. Funny thing is it was working fine three days ago. Please help. thank you
What happens with Sketchup open if you hit the windows key + shift and the right arrow key or the left arrow keyat the same time depending on which side the monitor is set to?
Yes, but I’ve tried with and without them. the same result.
Something else to try Reset work space in preferences and restart Sketchup.
window key + arrow did the trick. It was hidden outside of the frame. Thank you so much!
