Dimensions between sketch up and layout
Hi Can any one inform me how to adjust dimension font sizes? when i send a model to layout then export as a PDF the dimensions shift and overlap! I would like to be able to select them in layout and reduce the font size.
Paul
You can’t select SketchUp dimensions in LayOut. You can go back to SketchUp, adjust the dimension text size, save the file and update the reference in LO (sounds harder than it is) or you could just put the dimensions in using LayOut’s Dimension tool.
Thanks Dave, how do you adjust in sku?
Go to Window>Model Info>Dimensions. Adjust the font size. Select the dimensions you want to change or click Select all dimensions and then Update selected dimensions
