I discovered an issue with dimension settings under model info tab. If I set my dimensions to align to screen, close the box, then, create a dimension, as I drag to set the dimension, it displays correctly; in this case align to screen. However, when I click to set the dimension, it goes to “align to dimension line”. Note that I can change selected dimensions to “align to screen” by clicking the update button or selecting the dimension from the entity info in the tray, but this shouldn’t be necessary.
This feature behaves normally in SU 2023. I just tested it. Has anyone else experienced this behavior? Is this a known bug?
