Ive posted this topic before but I need to brainstorm with people on a solution.
We separate our floors by level tags in the model. But to make elevations look right, I need to hide lines on the exterior walls…
This all works great up until i need to section and dimension floor plans. Because the lines are hidden, dimension lines wont snap to them.
The solution I’ve done thus far is to turn on hidden geometry in the plan view scene. This works but the hidden geometry bogs down layout, I was wondering if anyone has ideas to be able to dimension hidden lines in layout?
I sometimes need to do that sort of thing. The process I’ve used is to wait to hide the edges until after the dimensions are in. Also I would set the style temporarily to Monochrome or Hidden Line and leave shadows off to reduce rendering times until dimensions and annotations are complete. You could do that part in LayOut for the viewport by choosing the style and disabling shadows. Once you’re set with the dimensions, hide the edges in SU and update in LO.
