Dimensioning is incorrect in layout
All three sides of an obtuse triangle are the same dimension in the latest update 16-April-2026, that is incorrect.
Can you post a file?
How did you draw the triangle?
Did autotext somehow get replaced with a simple number? If so every dimension would show that same number.
I received the following information from our South African Sketchup agent:
I re-scaled the Viewport that was the problem and it has resolved the issue. (I think a bug somewhere)
This seems much more like a LayOut/SketchUp update bug or model corruption issue than a simple dimensioning mistake—especially since:
  • :check_mark: Same geometry gives correct dimensions in a clean model
  • :cross_mark: But shows equal triangle sides (wrong) in the full model
  • :check_mark: Issue appeared immediately after updating
So you’re dealing with either:
  1. A bug introduced in the update, or
  2. Model context/scaling corruption that the new version is handling differently
  3. From your screenshots:
    • In the “full model” version, LayOut is likely misreading the model scale or viewport transformation
    • The triangle dimensions (310 / 320 / 640 etc.) are being interpreted as equal, which usually means:
      • The viewport scale is broken, or
      • The geometry is inside a scaled group/component, or
      • There’s a non-uniform scaling transformation somewhere in the model tree
    The fact that copy/paste into a new model fixes it is a huge clue :backhand_index_pointing_right: hidden scaling or corruption in the original file
You’ll have to post the LayOut file for anyone to make sense of it or have the SKP team take a look at what you think is an issue with the current update.
:white_check_mark::money_bag::luggage::chequered_flag:
This is a generated GPT AI response that as might be expected has some relationship with reality and also a bit of nonsense. Upload your model here so an actual knowledgeable human can examine and diagnose your situation.
Is the camera for the scene in SketchUp set to parallel projection?
