I’m using SU Pro 2020, and I can’t sfind the Dimension Style window in LayOut. The application says the window is open, but it’s nowhere to be found on screen. I’ve tried quitting and restarting SU, and restarting my MacBook, but nothing seems to work. Any suggestions? Or am I being told it’s time to upgrade to SU 2023?
Hi, did you find a solution for this issue? I’m having the same problem currently.
No, but the dimension style window mysteriously reappeared on its own.
@rssanders92 and whomever else may encounter a similar problem,
It might be that your dialog is trying to show up on an external monitor that is no longer there, or some similar situation. In any case, you can use the Arrange Panels menu item in the Window menu to reset the inspector dialogs to their default location:
Hope this helps,
Adam
Good. Thanks.
