Developer Needed - Panel Creation Extension
#1
I am hoping to find a developer that can help with automating the process of extruding and adding framework to our drawings.
I’ve attached an image and a sample file to better explain. We basically start with a flat shape and add lines throughout. We then push and pull the lines to create the contours. The time consuming part is then pulling each section to create individual panels which will be 3/4" plywood in real life, then adding 2x4 supports on the back which is how we attach the panels together once they are machined.
Thanks!
Mike
DeveloperSampleFinal.skp (196.3 KB)
#2
