Hello,
I am attempting to deploy an application built using the SketchUp SDK within a Docker container with servercore:1909. The application is being built using node-gyp into a .node file to be callable through a Node.JS server. I have attempted/done the following but still get a crash (without error) when executing:
- Building the program as an .exe and running it (It crashes without error)
- Installed Visual Studio Build Tools 2015 and built using that
- Installed C++ runtimes for 2015, 2017, 2019
- Put the two .dll files at the root of the project and in the build folder
The thing is, this execution flow works fine on a desktop Windows 10 instance. It works correctly on multiple development machines, including one that had a clean install.
I have a feeling it has to do with some of the system DLLs that the SketchUp SDK is calling internally, which may not be present in the stripped down server core image.
I know it’s a unique situation but any help would be appreciated!
