hey there,
I accidentally deleted all tags in my tag list while wanting to add a new one…
to make it clear, all tags are still visible in the model and while inspecting the different elements I can still see them being assigned to the model,
but i cannot see them in my list. This is empty
somehow couldn’t reverse the action…
so i am a bit stuck here with a complete model but an empty tag-list
thanks for any help
Christian
If you have enabled the auto save option, check if you can open the auto saved file it usually has the same name of the file but with a ~ at the end. Or close the file without saving it and open it again, it will show everything you did until the last time you saved. If none of those options work, cause the file was saved or auto saved after doing the action you want to revert, I don’t think there’s a way to do it, or maybe there’s a solution but I don’t know it, perhaps @colin can help you.
