I am using the most current release of SU 2022 Pro. I am not able to delete a component from a model. When I right click on the component name the Delete option is grayed out an not available. The method described by john_mcclenahan that works in SU 2017 Make does not work for SU 2022 Pro.
SO: How do you delete a component from a model in SU 2022 Pro, if the component is active in the model, or if it is not active in the model?
From where are you trying to delete it? The model space? The components panel?
Share the .skp file so we can see what you’ve got set up.
By the way, your profile says you are using SU2017 Make please update your profile.
