So here is the situation. I have started designing a desk for my room and i so far i have 4 components. They are listed as follows:
Leg
Short Skirt
Long Skirt
Top
If i have 4 copies of the leg, 2 copies of the short skirt, 2 copies of the long skirt, 1 copy of the top, and then assign an Instance name to each copy of a component in the Instance dialog box in the Entity Info panel i get the following list in Outliner:
NOTE: The less than and greater than symbols in outliner that encompass the definition are replaced with parenthesis since i cant seem to be be able to use them and have them displayed as they are in this forum.
Outliner List:
Right Back (Leg)
Right Front (Leg)
Left Back (Leg)
Left Front (Leg)
Left (Short Skirt)
Right (Short Skirt)
Back (Long Skirt)
Front (Long Skirt)
(Top)
Do you guys see the problem with this? Shouldnât the definition name be on the left and the instance name on the right so that the four legs, two short skirts, and two long skirts are evenly aligned in outliner. In other words, wouldnât the list make more sense if it were like this:
Outliner List:
(Leg) Left Back
(Leg) Left Front
(Leg) Right Back
(Leg) Right Front
(Long Skirt) Back
(Long Skirt) Front
(Short Skirt) Back
(Short Skirt) Front
(Top)
I find my proposed list is much easier to read especially if one Instance name is much longer than another which results in a much larger distance between the names of the definitions from one row to another. Although I can understand the drawback of having them listed this way is that when reading the words âleg left backâ you are sort of reading backwards as opposed to reading them as âleft back legâ.
So i guess itâs a catch 22. SU reads them normally but it is not neatly listed. My proposed way is read backwards but is neatly listed.
Perhaps having the option to sort them either way would be nice.
