Default material showing through applied texture
Suddenly for a reason I can’t figure the default texture is showing through the applied texture.
I have purged everything possible and done the fix problems.
I can’t find any solutions, please help
Have you inserted any component located very far from the origin?
May be ‘z-fighting’, when surfaces are (almost) at the same location and SU can’t figur out which material to show, maybe somehow a copy of components was inserted by accident?
If possible, share the model for further inspection :slight_smile:
It might be part of the problem, but the screenshot shows clear OpenGL artifacts that result from very large model extents.
