DC volume attribute with update script
This bit of Ruby adds a volume attribute to a DC as expected. However the new attribute will not update on redraw and if you try to reference it in a new attribute by clicking on it, this error message appears. Any thoughts on how to correct or workaround either of these issues?
Thanks!
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance).each do |s|
      s.set_attribute "dynamic_attributes","vol_inch", s.volume
       $dc_observers.get_latest_class.redraw_with_undo(s)
Edit: If you manually enter =vol_inch the new attribute works as expected.
Related topic.
Almost all dynamic attributes are attached to a DC’s definition. Any of those that have values that differ from the definition are also attached to the DC instance. The last different value is also saved into the definition for use as the default value for the next instance of that DC. (Note that nested dynamic groups always have the dynamic attributes attached to the instance.)
So it not surprising that all a dynamic property’s supporting attributes get properly added to the definition and the instance (as required) when you use the manual interface.
Use Aerilius attribute inspector. to see what attributes are created with each addition to a DC.
By adding the _“some new attribute” _label to the list of created attributes first, assures its defined
      s.set_attribute "dynamic_attributes","_vol_inch_label", "vol_inch"
probably best to add to the definition rather than the instance
Yep that fixes the click to add problem, thanks Philip. Any idea on making it update on the redraw? It would be SUPER cool to add that functionality.
Add Volume to component definition:
  s.definition.set_attribute "dynamic_attributes","_vol_inch_label","volume_inches"
  s.definition.set_attribute "dynamic_attributes","vol_inch", s.volume
Code should always check groups and instances if they are actually dynamic before setting attributes as Entity#set_attribute will create a new AttributeDictionary if none exists.
Ie, dynamic groups must have a “dynamic_attributes” AttributeDictionary … and dynamic instances must have an AttributeDictionary at the least attached to their definition. (They might also have one attached at the instance level depending upon whether they can have attribute values that differ from those in the definition’s dictionary.)
Add Volume script a la @DanRathbun
model = Sketchup.active_model
dco = $dc_observers.get_latest_class
model.selection.grep(Sketchup::ComponentInstance).each do |inst|
  dco.set_attribute(inst,"_volume_label","volume")
  dco.set_attribute(inst,"volume",inst.volume)
  dco.redraw_with_undo(inst)
This script updates all of the volume attributes in the model, created with the above script.
dict = "dynamic_attributes"
model.start_operation("Update Volume")
def select_children(instance)
  children = instance.definition.entities.select { |e| e.respond_to?(:definition) }
  instance.model.selection.add(children)
  children.each { |c| select_children(c) }
model.entities.each do |d|
  select_children(d)
  model.selection.add(d)
model.selection.each do |v|
  if v.get_attribute dict,"_volume_label","volume" == true
    v.set_attribute dict,"volume",v.volume
model.selection.clear
model.commit_operation
… except that such code, I always wrap in a submodule within an author namespace module.
Ie, it is not nice to define global methods or global references other than a toplevel namespace module.
Care to show me what that looks like? I always like to do my best to be nice…
Maybe like this?
module Build_Vitruvian
  module DC_volume #adds a volume in cubic inches attribute to a DC
    model = Sketchup.active_model.selection
    model.grep(Sketchup::ComponentInstance).each do |inst|
And the rest…
  module Update_DC_volume #updates all volume attributes created with DC_volume
     select_children(d)
