DBS
October 9, 2020, 10:00am
1
I created the extension for pipes, tubes, and profiles.
it lets to draw pipes, rectangular tubes, and common construction profiles
automatic elements numbering
allows editing its dimensions and length later
creates complicated joints
has useful elements positioning tools
make quick screenshots with elements length
makes Bill Of Material
calculate cut optimization!
Available:
SketchUp extension Pipes Tubes Profiles 2020
and
EW - Pipes Tubes Profiles 2020
Try the trial straight from SketchUp
Sketchup - > Extension warehouse → search: Pipes Tubes 2020 → Install Trial
Check the video tutorial on the youtube playlist:
VIDEO
DBS
February 19, 2022, 4:23pm
2
If you use Solid Tools operation to create holes in your model check below short youtube video .
You will learn what you need to do if your solid operations results are not as expected.
DBS
July 17, 2023, 12:31pm
3
New update on the extension !
What’s new?
v5.2
changes:
new settings option: Merge collinear edges (allows to create separate pipes or one pipe based on multiple edges)
move main menu cmd to DBS submenu
added About page
Check the short YouTube video with the new function:
DBS
September 13, 2023, 11:48am
4
New update on the extension!
What’s new?
v5.3
changes:
New settings option: Numbering start index
Watch the video to learn how to use it.
DBS
December 11, 2023, 2:24pm
5
Check the article where you can find SketchUp pipe extensions comparison
