Hello everybody,
Since I have installed the new release of 2023 I have an issue with my cutting tool.
I click on the cutting tool icon and then I normally choose first the solid that cuts and then secondly I select the solid that will be cut. Normally, you can get going on cutting solids with the same solid cutting until you press the esc key (and go back to step one, cutting solid selection) or press the space key or choose and other tool to stop the cutting tool process.
With the new 2023 release I can’t make it work that way anymore. Now I can cut one solid then the procedure stops (I can’t choose another solid to cut) and I have to push the space key, then I have to click on the cutting icon and redo the procedure all over again.
Anybody has a solution to make it work as normal ?
I appreciate it.
David from Belgium
