Cutting repeated irregular holes in a solid
Say you have a plank of wood that you create a hole through. But the hole is flared, as in countersinking, ie, the hole is wider one side than the other. Now you want to copy that hole multiple times. You obviously do not want to have to go back over each copy creating and then deleting surfaces. So what is the smart way?
You could model the hole as a solid group/component and copy it where you need. Then use Subtract from the Solid Tools to cut the holes in the plank. I would copy the geometry inside the hole cutter object so there’d only need to be one Subtract step. Here I’m using Eneroth Solid Tools for the Subtract step.
sub
Dave method is the most efficient but, just in case you want to practice with basic tools, click in sequence on the scenes tabs of this SU file for ideas.
Array of tapered holes.skp (233.7 KB)
Dave’s Subtract method works for any hole shape. If these are countersunk holes for screws or bolts, there’s also a faster way: we make an extension called screwit3D that does exactly this. Click the face and it drills the countersunk hole (through the plank, or blind), with the real countersink size for the screw you choose, DIN/ISO metric or ASME inch. Place one, then select two and it fills in the rest evenly between them. The holes go into the component, so every copy of the plank gets them too.
Here the bolt is shown pulled out, so you can see the countersink:
Same for wood screws, with the clearance and pilot hole sized for the screw:
Free version here if you want to try it: https://screwit3d.com
(Full disclosure: we’re the developers.)
