I have a complex solid group that I am going to 3D print. Unfortunately, I can’t print this because the printer’s max size is smaller than the model needs to be. My plan is to cut it in a way that the pieces lock together tightly. This is a high-quality Makerbot, so the pieces should fit together fine. I have made a group of pyramids so that when I cut the solid with it, one piece will go out and one will go in, thus they will fit together. The problem is, I cannot figure out how to get this group to cut. I need it to stay as a solid. I tried the Intersect tool, but the intersections don’t show up where they should; likely because of the complexity of the pieces. Ideally, I would end up with two solid groups that fit together. How can I do that? Is there a plugin that might help?
