Cursor snapping on 45 degree angles
anglesnap
anglesnapping
snapangle
protractor
#1
I am having a problem getting my cursor to snap at 45 degree angles. Under model info. units I have 45 degree snapping on
but it won’t snap to 45 degree angles. What am I missing here.
Thank you Steve
#2
Try keeping the mouse cursor inside or closer to the “protractor” widget to get the snaps. The further away you get, SketchUp aassumes you don’t want angle snapping.
#3
Do you see the number of lines (degrees) change if you select another snap-default ?
Also, it snaps on two of the standard axes (Red,Green,Blue) depending on what plane you are rotating.
