Hello everyone,
After submitting my new plugins to the extension bank, he asks me to fix some things.
Here is their message:
Here are the notes from the reviewer:
Observers should create transparent operations.
entity.model.start_operation('add texture', true)
Here is the code in question:
class MyEntitiesObserver < Sketchup::EntitiesObserver
def onElementAdded(entities, entity)
return unless entity.is_a?(Sketchup::ComponentInstance)
mod = Sketchup.active_model
mats = mod.materials
matatt = []
add_mat(entity, matatt)
matatt.compact!
matatt.uniq!
matskt = []
mod.materials.each{ |m| matskt << m.name }
matadd = matatt - matskt
plans_jpg = ['PLAN']
path_plans = File.join(Sketchup.find_support_file('plugins'), "TNT_ClickChange2/Materials/PLAN/")
last02 = mod.get_attribute("Plan","Last","27")
all = []
all << plans_jpg
matadd.each do |m|
unless all.include?(m)
matnew = mats.add(m)
if plans_jpg.include?(m)
matnew.texture = path_plans + "#{last02}-#{m}.jpg"
else
matnew = "RED"
end
end
end
entity.model.commit_operation
onElementAdded2(entities, entity)
entities.remove_observer(self)
end
def add_mat(entity, matatt)
entity.definition.entities.grep(Sketchup::ComponentInstance).each do |e|
attribut = e.get_attribute 'dynamic_attributes', 'material'
unless attribut.nil?
unless attribut == "#{ ""}"
matatt << attribut
end
end
add_mat(e, matatt)
end
end
TNT_COMPONENT_PATTERNS = [/TABLE SUR PIED CLC2/,/PLAN BAR/,/PLAN DE TRAVAIL DYNAMIQUE/]
def onElementAdded2(entities, entity)
return unless TNT_COMPONENT_PATTERNS.any?{ |pattern| entity.definition.name =~ pattern }
$dc_observers.get_latest_class.redraw_with_undo(entity)
entity.model.start_operation('Color Faces', true)
meubels_verven(entity)
end
PAINT_COMPONENT_PATTERNS = [/PLATEAU BAR/,/PLAN/]
DONT_PAINT_COMPONENT_PATTERNS = [/POIGNEE/]
def meubels_verven(entity, paint_subcomponent = false)
entity.definition.entities.grep(Sketchup::ComponentInstance).each do |instance|
next unless (paint_subcomponent) || PAINT_COMPONENT_PATTERNS.any?{ |pattern| instance.definition.name =~ pattern }
next if DONT_PAINT_COMPONENT_PATTERNS.any?{ |pattern| instance.definition.name =~ pattern }
if instance.material
instance.definition.entities.grep(Sketchup::Face).each do |f|
f.material = instance.material
instances_parent = instance.parent.name
stop = []
["V40","V60","V80","V100"].each do |lst|
stop << "STOP" if instances_parent.include?(lst)
end
if stop.empty?
f.back_material = instance.material
end
end
end
meubels_verven(instance, true)
end
end
end
This code is active when components with the definition “PLATEAU BAR” or “PLAN” are imported into SketchUp.
The goal is to create the material “PLAN” and apply it to the premitives of the components.
The code works well and I’m not sure I understand their expectations.
Can you help me understand that he is not going?
Thank you
