My first test in my sketchup extension to call c++ went like this:
Ruby code:
require_relative "test_projects//x64//Debug//test_projects.so"
if (SUEX_test.test1)
UI.messagebox("It works")
else
UI.messagebox("Fail")
end
And in the C++ I call it like this:
VALUE test1(){
return Qtrue;
// The initialization method for this module
extern "C" CEXT_EXPORT
void Init_test_projects(){
VALUE MyTest = rb_define_module("SUEX_test");
rb_define_module_function(MyTest, "test1", VALUEFUNC(test1), 0);
And it works, opening a message box in sketchup that displays “It works!”
I get how that works with VALUEFUNC returning a value of true.
The code below is sample code I got from (Tutorial: A Simple Window) that creates a window. I want to create a window in sketchup to add options to but I can’t seem to find any tutorial help on that. All I can do is create a basic toolbar that when clicked it opens up a webpage, but I want it to open up a window. If anyone has any tutorials that might help that would be nice. Below is the code that creates a window in c++. How can I call that in ruby and then in sketchup. I tried creating a ruby window.
I require ‘tk’
root = TkRoot.new { title "RPC"}
TkLabel.new(root) do
text 'This is the RPC window'
pack { padx 15; pady 15; side 'left'}
end
Tk.mainloop
But i get the error : Error: #LoadError: cannot load such file – Tk
Below is the c++ code I would like to see work.
const TCHAR g_szClassName[] = TEXT("myWindowClass");
LRESULT CALLBACK WndProc(HWND hwnd, UINT msg, WPARAM wParam, LPARAM lParam)
switch(msg)
case WM_CLOSE:
DestroyWindow(hwnd);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return DefWindowProc(hwnd, msg, wParam, lParam);
return 0;
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCMDLine, int nCmdShow)
WNDCLASSEX wc;
HWND hwnd;
MSG Msg;
// Registering the Window Class
wc.cbSize = sizeof(WNDCLASSEX);
wc.style = 0;
wc.lpfnWndProc = WndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon(NULL, IDI_APPLICATION);
wc.hCursor = LoadCursor(NULL, IDC_ARROW);
wc.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
wc.lpszMenuName = NULL;
wc.lpszClassName = g_szClassName;
wc.hIconSm = LoadIcon(NULL, IDI_APPLICATION);
if(!RegisterClassEx(&wc))
MessageBox(NULL, TEXT("Window Registration Failed!"), TEXT("Error!"), MB_ICONEXCLAMATION | MB_OK);
return 0;
hwnd = CreateWindowEx(
WS_EX_CLIENTEDGE,
g_szClassName,
TEXT("The title of my window"),
WS_OVERLAPPEDWINDOW,
CW_USEDEFAULT, CW_USEDEFAULT, 240, 120,
NULL, NULL, hInstance, NULL);
if(hwnd == NULL)
MessageBox(NULL, TEXT("Window Creation Failed!"), TEXT("Error!"), MB_ICONEXCLAMATION | MB_OK);
return 0;
ShowWindow(hwnd, nCmdShow);
UpdateWindow(hwnd);
while(GetMessage(&Msg, NULL, 0, 0) > 0)
TranslateMessage(&Msg);
DispatchMessage(&Msg);
return Msg.wParam;
