I received a sketchup model and had to convert it to Layout. I was able to convert the model to Layout there was a problem with one of the Windows the lines were so close together even with the new line weight feature it was still to thick. When I try to build a two d window I can not get the dimensions length correct.when I need a dimension 2’ 0" it comes out to be 7/16". I hope you understand thanks.
Although your explanation is clear, it will help diagnose the problem if you upload the LayOut file.
Have you set and locked the scale of the veiwport? Right click – scale?
This topic was automatically closed after 186 days. New replies are no longer allowed.
