Copy from one layer to another?
OMG You are my angle :*
Hi, first post… My question is slightly different, but related…
I created a group and originally assigned it to a layer (A). Then I reassigned it to another layer (B) using the Entity box. Now, it seems to disappear when a close layer A and layer B.
Is there a way I can break the link between my group and layer A, so that only layer B controls its visibility?
Many thanks in advance.
It sounds as if you’ve assigned the group to one layer and the geometry within to the other layer. The edges and faces should always be on Layer 0. Only the group should get a different layer assignment. Open the group, select the geometry and set its layer assignement back to Layer 0 and your problem should be solved.
