From single component (like a floor joist) in my model, and I would like to copy it and then paste it at a set interval (say 16") along and axis for a set distance. The number of pastes would be determined by the interval & distance.
I know there’s a way to do this, as I’m nearly certain I have before, but can’t remember steps. I’m not an every day user, but I have been an intermittent user since 2002. Thanks in advance for your assistance.
Select the component.
Press M for move.
Press Option (Mac) or Control (PC) to start copying.
Move it in the direction you wish to copy.
Lock the direction as needed.
Type the distance. Press Enter.
Type x# to set the number of copies then press Enter.
I sincerely appreciate the reply, but I’m afraid both of you sort of lost me along the way. I copied the component, though I got lost with “Copy in the desired direction with the distance you want " Not sure how to copy in a direction or how to copy with a distance”. I know I’m doing something stupid wrong, and am not trying to be obtuse I swear
thanks for the reply mike. I followed the Select, Press M, Press Control, moved the direction I needed. But do I type the distance space x# EG: 16" x4 Cause when I do this using a space or a comma I get"invalid Length error". Again thank you for the reply but I got lost somewhere. My guess is there’s some part of this that is so crazy simple that you guys are assuming that I’m doing that part …(but I’m an idiot and am not) like I’m a 3 year old, if you wouldn’t mind. and thanks again sir.
Just a note about what you are typing. If the Model Units are set to Architectural or Fractional there is no need to type the double quote mark. Just type 16, press Enter, type x4, press Enter. You can also use * instead of x which is handier if you have an extended keyboard.
For a bit of clarity, it is a function of the Move tool, not a copy paste action as such.
You use the move tool to move a copy and you can specify a distance and a multiple and you can keep changing these options until you exit the tool.
Here you see me using the select tool, then the move tool, then a tap of ctrl adds the + next to the cursor meaning it is in copy mode, then I move in the direction I want and as you see the object is attached to the cursor, then I let go of the mouse and type a distance and hit enter, then type a number of repeats and hit enter and I can keep changing them as long as I use the right format, A simple number or decimal or fraction will be read as a distance but a number with an x or * in front or behind it will be read as a multiple. There are regional differences. And by using / instead of x you will space them between the first and last, as in equal spacing between these two.
A hell of a lot of words for a very simple action.
