Hi, I have been trying to create components to use as plant objects for a planting plan/generating reports. All going well until today when I attempted to edit the data (using the entity info) adding size data.
I make the change, save the component in my component library (via right click). I then check it works by dragging in the saved component into the same work space i saved from. Only thing is…it reverts back to the original version, to before i made the latest edit. I know it saved correctly as if i import into another document it works fine. If however the document had, at some point a previous version it changes the imported component.
I could, i suppose, take my drawing and move it to a new drawing but this seems a backwards way to go about it. I feel like i need to purge the file of all the component data or something but when i investigate there appears to be none.
If it makes any difference, my sketch up version is 2021 but i need to save all my documents as 2017 so my team can access (they are all on 2017, yes yes I know!)
Thanks in advance
