I make an object then select all connected and make it a component. After this when I select part of what was supposed to be a block only the part that I touch is selected, not the entire block. If I try to move the entity I select only it is moved and the other parts “rubber band” to it, If I select all connected it will select the entire object the way that it should if it was a block. I hope this makes sense.
I’m using windows 10 and Sketchup Make, Version 12.2.2555 64bit
Something else that I noticed might be causing the problem. Every time I open up Sketchup Make I get a notice that there are extensions that need updating. Also, there is an extra item in the windows taskbar with the Sketchup logo. When I click on it a Microsoft Office Outlook notification pops up stating that
“Either there is no default mail client or the current mail client cannot fulfill the messaging request. Please run Microsoft Outlook and set it as the default mail client.”
