Hi - my component window has disappeared in Sketchup 2017. I have read every forum on how to fix it but it simply will not reappear making it impossible to use. i have reinstalled SU 3 times, tried different monitors etc but it cannot be fixed… any ideas?
Do you mean the Component inspector in the tray? That can be shown from Window > Default Tray > Components.
Hi Julia
Thanks for the message – it has suddenly popped up again….
I am also trying to calculate volumes – see attached file with a wedge like shape labelled TSF1 TAILS… is there some simple way to do it? I have been told that you have to remove lines etc… I tried
a Plug in called Volume Calculate 2 …an rbz file – couldn’t get it to work…
I see you are from Lund – I used to work for Tetra Pak and spent some great times there – fantastic place – especially in summer!
Best wishes
Tim Graham
Director
T: +61 1 300 78 64 62
M: +61 457 414 935
E: tgraham@minsep.com.au
TAILS MINING PLAN REV 8 20190407.skp (1.67 MB)
Lund is a lovely little town, and I’ve officially declared it summer here some weeks ago (I don’t care of the hail; it is not cold, just chilly now on).
If you make something a group or component SketchUp shows its volume in Entity Info without using any extension. However, you may need to use ThomThom’s Solid Inspector to assure the group/component actually represents a closed shape with a defined volume.
in the future you can start a new thread when you have a new question on another topic.
