I want to add a bunch of door labels to be determined later.
This would be helpful.
It would also be helpful to extract text object counts to build schedules more easily.
I’d also like this.
You can do the first with auto text, no?
I often have notes like ‘Post Bottom Typ. 1, Connection TBD by Engineer’ - then come back later and update the auto text when I coordinate with my PE.
The second, yes, that would be nice, but I often have text left on every page, for use I just drag it over where I need it and change the layer… so for me I’d get weird counts.
Can’t you extract the schedule from the model, where I assume the door count would be accurate (if you made individual components as needed, and updated their names / etc.)
I am sure I could make something like this using autotext… I hadn’t considered that before*
I would need to mess around with it a bit to get what i want out of it I think and I am not sure it would work as a scrapbook element, which I would also like to have as an option
We typically pull from the scrap book so there aren’t often many remnants laying around in the margin for our workflow. Overall I just have an issue with the general lack of BIM outputs in SketchUp. Although I have some ideas, I just don’t really have the time to investigate properly
Do you have a way you do this? I think I could potentially add more information to my components but again, don’t have a ton of extra time to investigate this
Generate Report?
Name the components per the manufacturers model or whatever you need in the drawings. You can also likely add data via a dynamic component.
I have a dedicated list plugging for extracting timber / framing piece count and sizes out of a model - but I often use it to just get dumb counts for windows, doors, etc.
While waiting for new feature, you can import a SketchUp file with 3D text. It will work as a component. If you want to update component, just open SketchUp to edit then update changes in LayOut.
