Component loses its property (TrueBend)
why a compound looses its property after using a tru bend plugin to bend the group. of copmounds?
I mean when (couloring, resizing …etc) the compound , does not effect the others.
hi,
what ?
a compound ? you mean a dynamic component ? what’s a compound in sketchup ?
I guess I’m missing a few words…
Try in your own language. many people do post in their own tongue, it’s often simpler for us to translate in our.
also,
Capture d’écran 2026-03-22 à 08.49.34
any chance that’d be a crak ? because that would explain the problem.
yes, merci, i mean a compounent. The problem is: while using a trueBend plugin to bend a group of compounents, ..the compounents behaves like a single, …couloring , resising pushing … doesn’t effect to all.
Try upgrading to 2026 and see if the problem persists.
When you move vertices in a component (bending), SketchUp cannot maintain the connection, so the component is copied and made unique. You should see a “#1” appended to the name of the bent component.
