I am making some components from switches and outlets (sockets).
The component from the single outlet works fine and cuts the opening in the wall.
I made a opening cutting component from the double outlet. When I insert this component
on the wall it doesn’t cut the opening. What is the difference between de single outlet and this double one?
You’ve grouped the double socket with the wall so separate them and
try again. As I post I note Box beat me to it - again!! So if you’re happy mark his as the solution.
