I’m using Sketchup 2014 Make via VirtualBox. When I right click on a selected component I get a ComponentDefinition warning (yellow triangle) and two others. This keeps me from copying, pasting, pasting in place components. The attached picture shows the first warning.
I can’t read the text of the the error. Perhaps you could copy and paste the exact text or make a screen shot of just the error. Could you share the SKP file? If it is an issue with the model, we should be able to reproduce it.
I have VirtualBox with 2014, and I pasted a component just fine. That’s all you’ll get out of me, because it looks like you have a bunch of extensions loaded on an unsupported platform, so I think your expectation level is a bit high.
Make sure you have the latest updates of all Ruby extensions.
Turn off all extensions, but the Dynamic Components extension. Does the issue still occur ?
If so update Dynamic Components. If not trun on extensions one by one testing until you find the culprit.
I unchecked all extensions except dynamic components exited and relaunched Sketchup - the error still occurred. Next I went to the ruby console and typed
Sketchup.plugins_disabled=true
Exited and relaunched and the error is gone. So now I will get updates and turn the extensions on one by one.
Thank you for your help. Is there a way I mark this as solved?
If you’re the thread starter, you’ll have an extra icon at the bottom on the far left (the check box). Everyone else gets those icons without the checkbox. Ah, you found it!
