Hi Dan
Thanks for your help. I found the answer in the end. Actually two solution.
Dp
Hi Im curious what you came up as a solution. I am also looking for something similar. A default setting if you will. This way you could mass change components ie materials, door style, build settings…
thanks
This can be done with the EntityInfo inspector by selecting multiple objects. But EntityInfo inspector cannot restrict the choice of materials per the values given in the DC properties dictionary.
I’m not sure if the DC Component Options interface can collect a common set of choices either.
