Complex shapes with the solid tool
Hello,Annotation%202019-04-08%20092401
I have a question about the solid tools on sketchup. I want to make a shape. I wish to make an intersection between the two solids: the pavement: and the bar of portals. Using solid tools seemed the only solution. But impossible to make an intersection, Sketchup tells me that the shape of the portal barstacles applaties are not solid … Would you know how to do?
Thanking you for your help
Ingees
On face value, it would be a matter of creating “solids”. There
are several tools available to check this - such as Solid
Inspector.
@splatcreativeau, please don’t sign all your posts like is done lately. It’s quite distracting.
See: https://forums.sketchup.com/guidelines
48
Edited to remove signature. Please refrain from adding signatures from here on in.
Can you upload the model itself (a SketchUp .skp file).
That way, it’s easier to help you.
Thank you. Ill check this and tell you later.
