I have a strange problem! The color slider and adjusting transparency are incredibly jerky and choppy. Also, moving the menus and setting the menu size is very jerky. What’s going on?
This is what I see in LayOut 2025. Is it different for you?
It’s the same…but the selection of the colors by the sliders is so slow and choppy.
So not as smooth as in my gif?
@Barry, any thoughts?
No! Not that smooth.
In LayOut 2024 as your profile shows? Can you try in LayOut 2025?
Which graphics engine are you using?
Switched to the experimental graphics engine and that works a bit better.
I wonder if your display resolution or Hz is set to something different? I’m remoting into a PC and it’s smooth for me.
Barry
ps - but you’re asking the wrong person - I’m typically on a Mac, where the font and color panel are system-wide and applications don’t have to build their own.
pss - you can also enter numbers in the text box if there’s an exact RGB value you want.
