Collada files fail to import
This file was exported by 2020 Design Live, the only error I get is “Import Failed”. I have tried Sketchup 2021 and 2023, Skimp extension and Transmutr extension. Any ideas?
Collada File and attachments
I’ve tried it in Blender too - The file isn’t a valid DAE file and is missing various bits of information that any program that can open it will expect to see - so it it failing and not opening.
So a problem with the exporter.
You could try exporting as a DWG instead - that seems to be an option in that software.
Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Specification mandates value for attribute HIGH
The Collada import has been forced to stop.
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: attributes construct error
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: error parsing attribute name
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: xmlParseStartTag: problem parsing attributes
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Couldn't find end of Start Tag node line 104574
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Opening and ending tag mismatch: visual_scene line 0 and node
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Opening and ending tag mismatch: library_visual_scenes line 0 and visual_scene
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Opening and ending tag mismatch: COLLADA line 0 and library_visual_scenes
Please fix the reported error and then try again.Schema validation (Error): Critical error: ERROR_XML_PARSER_ERROR Additional: Extra content at the end of the document
