Continuing the discussion from Creating log files for ruby code:
Here is a couple of examples of using a module to encapsulate a Logger object for use by other submodules.
For reference this is the class documenttion for the Logger
class:
Simple edition:
# encoding: UTF-8
module AuthorTopLevelNamespace # outer namespace module
require 'logger'
module Log
PATH ||= File.join(ENV["HOME"],"Desktop")
FILE ||= "SketchUp_Plugins.log"
@@log ||= Logger.new(File.join(PATH,FILE), 2, 1024*1024)
# Redefine the method missing handler for this module to forward method
# calls to a Logger instance (@@log) if it responds to the method name.
# If this call is not meant for the Logger object, then just call super
# so the NoMethodError is handled normally.
def self.method_missing(methname,*args)
@@log.respond_to?(methname) ? @@log.send(methname,*args) : super
end
end
module SomePlugin # an inner extension submodule
extend self
# Within some method of this extension, a method call to the Log module
# forwards to it's Logger object, some text to be logged in the logger file.
def some_method
Log.info("Sending my log some information.")
end
end
end # outer namespace module
Deluxe edition:
# encoding: UTF-8
require 'logger'
module Log
# If the first argument is a String and it has a %s replaceable parameter,
# then replace that parameter with a Kernel#caller string.
if @@log.respond_to?(methname)
if args.first.is_a?(String) && args.first.include?('%s')
args[0] = args.first % caller_locations(0)[2].to_s
end
else
super # it's a real NoMethodError exception
end
end
end
extend self
# This local extension method will prepend logger text with the
# qualified module name and a replaceable %s parameter that will
# be replaced by a caller inspection string.
def log(text)
Log.info("#{Module.nesting[0].name}:%s: #{text}")
end
# With some method of the extension, a call to the log() method
# passes some text to be logged in the logger file.
def some_method
log("Sending my log some information.")
end
end
