# \[code\] Set Layer Colors menu command example
**URL:** <https://forums.sketchup.com/t/code-set-layer-colors-menu-command-example/26231>\
**Category:** Ruby API\
**Tags:** layer, color, layers, example\
**Created:** [June 8, 2016, 3:33pm UTC](https://forums.sketchup.com/t/code-set-layer-colors-menu-command-example/26231 "2016-06-08T15:33:44Z")\
**Showing post:** 2
**Post date:** [June 8, 2016, 6:36pm UTC](https://forums.sketchup.com/t/code-set-layer-colors-menu-command-example/26231/2 "2016-06-08T18:36:24Z")
The first example (above) can add a bunch of undo operations to the undo stack.
This example wraps the commands in named undo operations.
[set\_demo\_layer\_colors\_undoable.rb](https://forums.sketchup.com/uploads/short-url/xFwLPlENqi1HOYAZ0hSXFs6GkeU.rb) (1.7 KB)
```ruby
# encoding: UTF-8
# "Set Demo Layer Colors" & "Reset Layer Colors" commands.
# A SketchUp menu command example by Dan Rathbun. 2021-07-14
# This edition wraps the commands in undo operation blocks.
module User # <<<---<<<< Change to YOUR unique toplevel namespace
  module DemoLayerColors
    if !defined?(@loaded)
      UI.menu("View").add_separator
      UI.menu("View").add_item("Set Demo Layer Colors") {
        Sketchup.active_model.start_operation("Demo Layer Colors",true)
          for i in Sketchup.active_model.layers.to_a
            if i.name.start_with?("Demo")
              hue = Sketchup::Color.new("Red")
            elsif i.name.start_with?("New")
              hue = Sketchup::Color.new("Gray")
            else
              hue = Sketchup::Color.new("White")
            props = i.attribute_dictionary("Properties")
            ca = i.get_attribute("Properties","Color") rescue nil
            if !props || ca.nil? || ca != hue.to_a
              i.set_attribute("Properties","Color",i.color.to_a)
            i.color = hue
        Sketchup.active_model.commit_operation
      UI.menu("View").add_item("Reset Layer Colors") {
        Sketchup.active_model.start_operation("Reset Layer Colors",true)
            i.color = Sketchup::Color::new(ca) if ca
      @loaded = true
    end # if not already loaded
  end # extension submodule
end # top level namespace module
**EDITS:**
> **(click to expand ...)**
> 1. The above files had a conditional:
> 2. [2021-07-14] The `$LOADED_FEATURES` conditional test was removed and replaced with a internal conditional block using a `@loaded` variable. (This should be faster loading.)
_[View the full topic](https://forums.sketchup.com/t/code-set-layer-colors-menu-command-example/26231)._
