Embedded web views should continue to work. That retirement is for the IE browser app.
I’m afraid not. It’s hard when it’s not easily reprodusable on every machine.
Thats a shame. Would you mind if I throw it open to the rest of the community for any ideas to solve the problem?
This is not a private message… the whole community is already seeing this!
Hello ThomThom,
We’re having the same problem with cleanup.
Blank menu window.
what have I done already.
Uninstalled sketchup and deleted all the files in the appdata/roaming/sketchup
then Installed Sketchup (as administrator).
Then added the plugins. But still no menu arggghhhh
Is it possible it has something to do with the register?
Same bug, Windows 10 V 22H2
Are you referring to Cleanup3 by thomthom ?
Hey @thomthom …
unfortunately the bug still exists so I tried to fix it on my own. I checked the Ruby Console while pressing on »Clean…« in your menu. This was the output:
Error: #<NameError: uninitialized constant TT::Win32::OutputDebugString>
C:/Users/MARIOSUNSHINE/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/debug.rb:36:in `debug'
C:/Users/MARIOSUNSHINE/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/window.rb:32:in `block in <class:Window>'
SketchUp:1:in `call'
C:/Users/MARIOSUNSHINE/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/inputbox.rb:133:in `event_inputbox_ready'
After that I checked the debug.rb file and commented out line 36:
#Because of the annoying Window Bug in Cleanup³
#TT::Win32::OutputDebugString.call( "#{str}\n\0" )
Now it works again!
The window is not empty anymore and now I’m able to use it as planned.
But… I’m not really sure if this uncommented Line of Code will affect other ThomThom Plugins?
@thomthom: What do you say? Anny comments?
Greets Mario
@MarioSunshine : Followed your advice. It worked! Congrats.
This helps me a lot.
So far my installed other thomthom plugins (solid inspector, material replacer, selection toys) are still working.
Happy 2 hear that!
Have fun!
PS: I think the debug.rb File does not really affect other ThomThom Plugins. I think it’s more for debugging Plugins…
I looked at this a few days ago and found that in the latest revision of TT_Lib2 the file named
C:\Users\UserName\AppData\Roaming\SketchUp\SketchUp 20XX\SketchUp\Plugins\TT_Lib2\win32.rb
is missing a small detail. The following should be inserted after line 19.
include Win32Win32APIImpl # constants
This bug only affects versions of Sketchup that run Ruby 2.5 or earlier.
Edit :tagging @tt_su
Cool, that did the trick…
Thanks a lot!
Thank you Mario. I had same problem in quadface tools!
Thank you, thank you, thank you. This fixes the grey screen on Cleanup.
Version 2.13.1 has been published. This includes the fix for older SketchUp versions.
Available via Extension Warehouse and SketchUcation.
Sorry for the inconvenience.
Updated version has fixed the grey screen problem
Thanks
Sorry, but I am also having this grey screen while using cleanup. Updating with sketcucation does not change it.
Further I see there that it is version 3.4.3 and not 2.13.1 ?
I am using sketcup pro V19.
Any thoughts ?
By the way : using latest settings option the plugin runs
