Well… practice certainly does help!
An issue with .STL files is that the faces import cut into many, many pieces. Sometimes these faces can be quickly repaired, but often they just don’t clean up very well.
Well that did clear the text which is what I needed to be done. Now to see how it looks in RepG. I appreciate all the responses and help. I was not expecting that! Thanks again guys.
Another way to get rid of the text…
What version of SketchUp? (Exact version number please - all the numbers. You find it in the About dialog)
What version of Internet Explorer?
Which Windows version are you using?
I am running Windows10 Pro X64
I don’t use IE as a browser but it’s version is 11.212.10586.0
and I am using Sketchup Pro 2016 Version 16.1.1449 64 Bit
SketchUp uses IE to make many of its dialogs, irrespective of your preferred browser set up.
Sometimes clearing the IE cache can resolve issues…
Ok, Let me give that a try.
Edit: No change with that.
this is to funny …guyss
Aaron, how did you do that very last step where the top face after healing got rid of the the two extra lines? Did you just hide the geometry or is there a way you removed lines on the face?
I think he has used Thomthoms CleanUp³ for this step.
This is what I SHOULD have done… but I cheated and just softened the whole thing.
