I have a component consisting of four groups - frames with a fixed width 80mm in the form of a trapezium (Figure 1). When increasing the size of the component angels of trapezoid elements are chaneged (Figure 2). After changing the dimensions of the component would like to get a component as shown in Figure 3. Do you have any idea how to do it witchout scripts in ruby?
Thank you in advance for your help
For a dynamic component, you will have to create the frame from 8 parts: four corner pieces and four pieces for the sides. The connecting lines can be hidden to preserve the correct appearance.
Anssi
I did that, and it works. Thenk you very much.
Marcin
For extra credit - and a great learning experience, try doing it with only 3 components - using the COPIES predefined attribute, then using COPY in formulas for: A corner - with 3 copies that change location and rotation, 1 side - with 1 copy (moved and rotated) to create the opposite side, and another side, again with 1 copy (again moved and rotated) to create the opposite side.
I just finished trying to do something similar in order to teach myself about COPY and how to use it. I learned HEAPS about dynamic components while doing it!
