Is there a way to change what SU file my Layout doc is pointing to?
I copied my SU and Layout files to a new folder. Now I want to modify the name of the file a Layout viewport is pointing to. I looked in the Knowledge Center but could not find an answer. If I click on the “update model reference” I do not get an option to change the file name. Isn’t Layout still pointed to the original file?
You would do that from File>Document SetUp>References. Select the current reference file and choose Unlink. Then select it again if needed and click Relink. Choose the new file instead of the original SKP file.
If you just click on Update, it looks at either the original SKP file or the embedded version of it depending on what is available. Just putting the LO file in the same directory doesn’t change the link path to the SKP file.
Now that you gave these instructions I think I have seen that before somewhere. I did not find that in the knowledge center. I will try it as soon as I can get back to my computer
