Change amount of sections in arc/circle
Really simple one hopefully! I’m sure I’ve altered this before, now can’t find the setting. I draw very small radii so need to increase the amount of sections to allow the radius to be formed. Can someone please point me to the right place so I can adjust?? Thanks.
Entity Info panel
Thanks however this allows me to change the number of segments after a circle is drawn. Do you know how to adjust the drawing template so that you can draw a very small circle or import an image with very small radii? Need to pull in 0.2mm shapes from dwgs.
SketchUp - YouTube search?query=circle
E.g:
CircleTool - Square One - YouTube
However SketchUp does not “play nice” with such a small dimensions (edges). Better to scale the model up by 100-1000, and when you done you can scale down again.
(Also see : https://forums.sketchup.com/t/the-dave-method/49720 )
Usually, creating things with edges or segments smaller than about 1 mm may fail. SketchUp works best for objects with sizes ranging from small furniture pieces to a city block.
And how arcs are treated when importing dwgs is another matter.
that’s a great help, hadn’t thought of that!
