Can't See Nested Components
Solid Inspector said there was a nested component error. I can’t find it.
T. Frid’s Serving Cart.skp (122.5 KB)
You’re doing the same thing you did with the cabinet copying geometry instead of the component again.It appears you copied the loose leg geometry to make four legs and then selected the two of them and made a component to contain that geometry.
Bottom level.
Nest with a component and a bunch of loose geometry.
You’ve done the same thing to the rails on the top.
Quit opening the component for editing before you copy. Just copy the component.
Look at this revision to your model.
T. Frid’s Serving Cart fixed.skp (133.0 KB)
I need to stamp this on my forehead :confused:
