hi
created 2D walls and when tried to push/pull walls it’ll not work
please help! (1.6 MB)
thx much
eli
Your upload failed.
This is why. Your drawing is not all on a flat plane, which is required to create a flat surface. You’ll have to move all the geometry to the same flat plane and then push the walls up from there.
There are also two groups named walls that appear to be identical. That may confuse the issue.
Thank you very much.
Is it possible to get the fixed file you did?
I didn’t fix anything. I just looked at it from the side to see that you weren’t even drawing on a flat plane. I highly recommend fixing your file yourself.
Thanks
I wish i knew how.should i draw again from the beginning?
via gifyu
for mobile view
Use arrow keys to lock the movement on axes (up arrow for Z)
Learn the basics: SketchUp Fundamentals -Part 1
Thank a lot
Will you send me the fixed file?
It will help me a lot
Many thanks
Have you not even tried doing what he did? He shows exactly how to fix it in a couple of simple steps. Go ahead and give it a try, you’ll learn a lot.
A gif is worth a thousand words.
Thank you very much
Ill yry it
Appreciate all of you here for helping
it worked , you are the best
thanks a lot guys
