Hello.
im new in sketchup… i dont know if i can push a line Which drawn on a rectangle?
here is my file , please capture a video when u are doing it for me.
thanks.Untitled3.skp (97.2 KB)
alright , so how to push all these lines together?
What exactly are you trying to achieve? Maybe you need to be using the Move tool.
Move tool works , but only when the vertical line is straight.
just watch this video and u will see.https://global.discourse-cdn.com/sketchup/original/3X/0/d/0dbd0857046a2aed336db1099acbe18f4d03aa92.mp4
Use the Auto Fold feature. Again, what exactly are you trying to achieve?
You’re using Auto-fold in the first example in your video, but then Auto-fold isn’t turning on automatically once the line is angled. Press the Alt key to activate Auto-fold when it doesn’t happen by itself.
Yes that worked good but there is something wrong , idk why its creating these lines when i do that:(video)
https://ufile.io/jh6b0
Those additional lines are required to make faces because the four edges aren’t coplanar. It’s simple, fundamental geometry. In order to create a face, the bounding edges must lie on the same plane.
