After importing a simple file form Archicad 18, the model doesn’t want to show edges, or extensions. Scenes are downgraded in appearance. Can’t figure out the trick. I know there’s a simple solution out there.
Go to Window > Styles dialog where you will be able to change the visual edge properties
CD
Same problem here … to activate the Edges via Styles/Edit doesn’t work!
Could you share the SKP file?
Sorry NO. I am not allowed to share ongoing projects …
Is View > Hidden Geometry checked ?
Archicad makes all the edges “hidden” on export; you need to un-hide them.
(Turn “hidden geometry” on, select ‘wireframe’ view and select everything. Then use the entity info box to un-tic the ‘hidden’ box.)
Note that Arcicad also exports each wall and slab as a cube - rather than actually joining two walls at a corner you will find an additional line… and deleting it will remove the inner wall face. You may have to “intersect faces with model” and do a bit of tidying up.
Hidden edges + unhide ALL was the Problem!
Thanks a lot guys!
