Despite being fairly proficient at SU. I can’t solve this problem and would appreciate your help. I can no longer get close to my work. What happens is I start to zoom in to an object and even from quite far away (1-2 meters) it goes into that mode where I’ve entered inside the object, even though I’m no where near it. This entering into the object used to happen when I was within 1-2mm of the object, but now it’s from way out. It’s been an announce and I’ve worked around it for some time, but I really need to fix this.
The things I recall did prior to this happening:
1.) I did created a bunch of animations and played with a lot of the view settings (Walk Around, etc.)
2.) I upgraded to the latest version SU Pro 17.1.173.
I’m using SU on Mac OS Sierra. Thanks for your help.
-Fred
File too big to share. Your suggestions tell me I’ve not explained the problem well enough.
Let me try again. While zooming in to an object from about 1-2 meters away, I’m suddenly inside the object. I used to be able to get right on top of the object before this happened.
I notice the if I create a new model, this does not happen. Makes me think that I have changed some setting some where along the line, but what it is I have no idea.
For anyone who comes along looking for a solution to the same sort of problem, the issue was clipping due to a plane on the ground that is over 2 kilometers on a side (more than one-and-a quarter miles) and zooming in on a component that is less than 1 meter wide. Deleting the giant plane removed the clipping.
