I was working on a model, everything was fine and out of the blue the context menu for In model materials stopped working. When I right click on the material within Materials window, SU freezes for a few seconds, Windows says “Not responding”, the whole scene goes black, renders again and unfreezes, but the context menu won’t show. I tried to restart SU, but no luck. Have I added some material that causes the problem? How can I find out the reason or fix the project file?
Your profile states you are using v 14.0 ?
You should update to SketchUp v 14.1 or even better 15.3.
Close Outliner window, and turn off textures while editing materials.
I tried closing Outliner window and editing materials while in wireframe display mode, but it won’t help.
I figured out that Ligne Roset Ruche Bed | 3D Warehouse is the culprit. Since I added this to my project, I can’t edit materials. Even though I deleted the model from my project, deleted the layer it was added to, I can’t edit materials, I can’t purge unused ones. Is there anything wrong with this model?
That model has over 121,000 polygons.
You still need to purge the used component definition.
