Can't edit component
I imported an .ifc file to work on some equipment placement and have a couple of artifacts I want to delete. I try ‘edit component’ but it still selects everything. I can’t find a different way to import the file than I already did.
TIA
In an imported IFC everything is a component within a component within a … So opening one level of nesting might not be enough to get to the actual object you want to edit. Or then use the Explode function if you don’t like the nesting.
That was it, thanks! Had to do about 3 ‘edit components’ to dig into it
Seems like probably a little excessive on the nesting.
You should take advantage of Outliner to see the nesting levels and more quickly get to the required level.
