Can't delete models from 3D Warehouse collections
The thread title is the topic. I want to delete a few models from one of my 3D Warehouse collections, but I can’t find any way to do that with the new UI. I know the update is recent and there’s still bugs to fix, but I still thought I’d report this.
Thanks, Dan. Go to all your Collections in your account, and click on the “kabob menu” - 3 vertical dots: you get 3 choices to View, Edit, or Delete the Collection. Choose Edit.
Now click on the “Models” tab to view the models in the Collection, and each model will have a kabob menu to View, Edit, or Remove the model.
We are still doing work on the User Content Manager, but you should still be able to use this.
Barry
that is a little obscure… is that just a workaround until a more obvious UI adjustment is made ?
Hi - I am having this same issue, except there is no “kabob menu” appearing on the models within my collections. Can someone upload a screenshot showing where these three dots are supposed to be?
@kristi.kautz … dunno if you’ve found where @Barry was talking about yet or not since this thread seemed to have died. I was also looking for the “kabob menu.” It appears those verticle dots are presented only if you clik on “Use Classic” in the upper right corner.
Go to Collections as @Barry indicated. Clik on “Use Classic.” You will then have to clik on Collections down the left margin (the folder icon). Once your collections appear, you will see those three verticle dots on each collection just opposite the name of the collection.
I hope this is more clear… I am unable to upload images for some reason.
If you don’t have a kabob menu, are you sure you own that Collection? People sometimes sign into an account that they didn’t use to create the original account.
b
If I am understanding this correctly… you are editing your own collection. In particular, you are looking at the models in that collection (under the Models tab on the edit collection page). You see a card for each model in that collection. On those cards you have some icons. If you own that model, you will see a pencil icon (edit) that allows you to go to that model’s edit page. If you do not see a pencil icon (edit) then you don’t own that model. If you are trying to remove model(s) from your collection, you can check the little checkbox in the lower left corner of each of the model cards. Only check the ones you want to do something with. Once you check 1 or more checkboxes you will see a total of the items selected, 2 other icons, and Done button. First one (Add to collection) allows you to add those selected models to a collection and the other icon (Remove items) is to remove them from your collection. The Done button will get you back to the regular view you were in before you started checking those checkboxes.
